Headlight question
Old Oct 18, 2008 | 09:40 PM
AFultz87's Avatar
AFultz87
Exclamation Headlight question
I converted my quad beam Sport headlights to regular Ram 2 beam headlights. Problem is when I spliced them together, my highbeam dash light stays on. Causing my fog lights not to come on. Did I splice these wrong? Anybody with a Sport that has done this please help me out!
Old Oct 18, 2008 | 11:56 PM
jasonw's Avatar
jasonw
Site Moderator
You connected wires wrong somewhere. I have only ever had the duals, never quads as mine is not a sport, but when I was doing the relay wiring to take the load off the switch I had a wire somewhere connected wrong, and I had a constant high beam indicator light.
Go through with a test light or voltmeter and check each wire, see which are high beam, which are lows. The wire that doesn't seem to do anything (doesn't light up the test light/voltmeter no matter what you do with your lights) is the ground wire.
I'm assuming you went to the standard 9004 type bulb setup, right? If so, here's a graphic to help you out with what wire does what.
Old Oct 19, 2008 | 10:51 AM
aim4squirrels's Avatar
aim4squirrels
Jeez Jason,
that diagram would have saved me last week screwing with those headlights
Old Oct 19, 2008 | 12:59 PM
Viper37's Avatar
Viper37
I'm still at a loss for the headlight configuration of this truck. Is the ground switched? No matter what I do and how I connect it, I cant for the life of me figure out how to hook a relay to my high beam wire.
I really want to figure it out also, because if I can kick on my auxiliaries only when my high beams are on, I'll be able to get rid of that switch in my interior.
Old Oct 19, 2008 | 06:48 PM
jasonw's Avatar
jasonw
Site Moderator
Maybe this will help.
Let me know if I messed anything up.
Old Oct 19, 2008 | 07:12 PM
Viper37's Avatar
Viper37
Thanks man, but I figured it out this morning using that picture you showed me. I went out with my meter and a relay and got it all figured out.
Once the Male 9004 Socket arrives, I will be able to independently turn on my lights, and kill them all at the same time by turning off my high beams.
Bad ***!
Thanks mate.
Old Oct 19, 2008 | 09:47 PM
oiler's Avatar
oiler
Besides the wiring, will the non sport headlights bolt right up to a sport model? Or is there any fab work involved in making them fit? Thanks.
Old Oct 20, 2008 | 04:25 PM
AFultz87's Avatar
AFultz87
no...no fab work just need to do wiring work
Old Oct 20, 2008 | 08:09 PM
oiler's Avatar
oiler
Cool! I like the 2 bulb set up but theres not many after market options. Thank you.
Old Oct 21, 2008 | 03:33 PM
AFultz87's Avatar
AFultz87
no kidding...i hate there isn't a quad beam after market headlight out there. but oh well....btw i found another Sport that did this conversion...anybody know who this guy is and how i can get ahold of him? Says his name is Don from Winnipeg, MB, Canada
