5.9 magnum bogging?? fuel injectors maybe???
Old Oct 22, 2008 | 01:41 PM
neattouch648's Avatar
neattouch648
Default 5.9 magnum bogging?? fuel injectors maybe???
okay this one i can't really figure out....the truck is throwing no error codes, but if i'm stopped and i step on the gas to accelerate quickly, the truck doesn't accelerate nor does the rpm increase. rather the rpm decreases to like 300 rpm and then it takes a couple of seconds before the truck actually moves, before the motor actually gets its rpms up...anyone have any idea?
Old Oct 22, 2008 | 04:23 PM
lastrights's Avatar
lastrights
sensor somewhere , looks like you got something wet, by the picture in your sig lol
Old Oct 22, 2008 | 04:44 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Perhaps the IAT is not fully retracting?
Old Oct 22, 2008 | 05:03 PM
dodgeram07's Avatar
dodgeram07
have you checked your cat???
Old Oct 22, 2008 | 09:36 PM
ryirocz's Avatar
ryirocz
try the crankshaft positioning sensor
Old Oct 22, 2008 | 09:44 PM
pcfixerpro's Avatar
pcfixerpro
haha maybe even the tps. Looks like you got your work cut out for ya.
Old Oct 22, 2008 | 09:55 PM
aim4squirrels's Avatar
aim4squirrels
If its a sensor, my money would be on the TPS, but you've got a lot of choices here.
From cheapest/easiest fix to most expensive:
1. Remove Throttle Body and Clean with Brake Parts Cleaner or the like. Reinstall and retest.
2. Test Catalytic Converter with a temp gun, if it's hotter going in than coming out, the Cat's clogged and needs to be replaced.
3. Test Fuel Pump at Schrader Valve on fuel rail to make sure it's holding 46-49 PSI at all times and in all conditions.
4. Replace TPS, IAC, or both
5. Replace Crank Sensor. PITA to get to and about $80 if I remember correctly.
Old Oct 24, 2008 | 01:33 PM
neattouch648
haha to clear it up...the picture in my signature is from like 2 years ago in the rio grande....truck has been running great since then. it wasn't until lik ethree days ago that it started doing this bogging thing....
where is the IAT sensor located?>?
