Abs & break
Old Oct 22, 2008 | 08:37 PM
mfrump's Avatar
mfrump
Default Abs & break
Im getting a abs a break light on my 2000 dodge ram 1500 4x4 i just comes on when it feels like it i can just be driving down the road and it will come on ???????? is it a wheel sensor or somthing like that
Old Oct 22, 2008 | 08:45 PM
Viper37's Avatar
Viper37
It could be the sensor. If I hit a speed bump hard enough and just right I can get my ABS/Parking Brake lights to come up.
Old Oct 22, 2008 | 11:22 PM
dodgeforlife15's Avatar
dodgeforlife15
it is most likely one of the abs sensors. there are two in the front and one in the back, at least on my truck. it doesn't really cause a problem unless you mash the brakes. if you slam the brakes while one of these sensors is malfunctioning, the wheels will lock up.
Old Oct 23, 2008 | 11:15 AM
simpsonna's Avatar
simpsonna
Mine will come on randomly when the connections get dirty. Any time I get the truck good and dirty I have to crawl under the truck and disconnect the two connections right over the rear diff and spray them with contact cleaner. But after that they work fine... until I get it dirty again.
Old Oct 24, 2008 | 06:12 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Check your fuses first, then check your front hubs and see if you have wires coming out of them from the back. If you don't see any wires you only have RWAB. And as stated above, try cleaning the connectors on top of the rear end housing before replacing the sensor.
If you do have wires on the front , check your hub bearings, because no amount of cleaning will fix the front as they are built into the hub/bearing assembly.
