DIY 2wd ball joint replacement
Old Jun 25, 2009 | 03:50 PM
xray99's Avatar
xray99
If your control arm is cutting your tire, you should do something, and do it quick.
That is pretty drastic ,,, And it is almost always advisable to get an alignment after major front end work, which balljoints would qualify as.
Old Aug 6, 2010 | 06:38 PM
joeuc23's Avatar
joeuc23
Thanks for the pictures!!
I will be attempting this tomorrow morning. The one question I have is...how do you properly torque the bearing nut? Seems many reference show having the hub. I'm just leery of using 185 ft-lbs. I don't want to destroy my new bearing.
Thanks a bunch.
Joe
Old Aug 6, 2010 | 07:19 PM
J415's Avatar
J415
Why isn't this in the DIY section? Or is it?
Old Aug 6, 2010 | 08:08 PM
VEETEN's Avatar
VEETEN
185 ftlbs is for the sealed hub bearings on 2wd
dodgeram07 (the DIY poster) has the old plain timken tapered roller bearings which I believe are torqued alot lower.
maybe someone with those can confirm.
Joeuc23 what do you have on yours?
what year?
Old Aug 6, 2010 | 09:03 PM
joeuc23's Avatar
joeuc23
what year?
I have a 1999 4x2 with the "old plain timken tapered roller bearings"
Thanks,
Joe
Old Aug 6, 2010 | 09:07 PM
dodgeram07's Avatar
dodgeram07
ya dont torq they to 185 or you will have problems
just tightin thill the play it out of the rotor, but the rotor still turns feely
Old Aug 6, 2010 | 11:00 PM
joeuc23's Avatar
joeuc23
Alright...Thanks all.
Hopefully the ball joint (upper and lower) and bearing replacement goes well tomorrow.
Thanks again,
Joe
Old Oct 1, 2010 | 01:57 PM
coongobbler's Avatar
coongobbler
Question 2WD Ball Joint Replacement 98 RAM 5.9L QUAD
Great write up! My ball joints are wore out on both sides (Upper/Lower). Followed your instructions. Removed driver side lower joint with no problems. My truck ball joints look exectly like yours. However the top hat plate on the upper ball joint does not indicate a tack weld. Do I cut this plate in half for removal?
Any help would greatly be appreciated,
coongobbler
Old Oct 1, 2010 | 02:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Don't cut any plates,you have to grind off the rivets.
Old Apr 17, 2011 | 07:18 PM
stewie01's Avatar
stewie01
So what are we supposed to torque the new ball joints to there aren't pressed in?
