Pinion Nut
Old Nov 6, 2008 | 01:47 AM
Thumpper369's Avatar
Thumpper369
Default Pinion Nut
ok I have a 2001 Ram 1500 4x4 5.2L with the 3.55 rearend, I have to replace the pinion bearings I was wondering does anyone know what the torque specs are for retorquing the Pinion Nut? i have a few books but they dont tell me oh wait I just looked and found it, it says 210 ft lbs does that sound correct?
Old Nov 21, 2008 | 11:53 PM
DodgeAdvisor's Avatar
DodgeAdvisor
Yes that is correct but the most important specs is the pinion bearing preload,as in the rotational torque on the pinion shaft. With new pinion bearings it should be 15-35 INCH/POUNDS and original bearings should be 10-20 INCH/POUNDS
Old Nov 22, 2008 | 07:12 AM
HankL's Avatar
HankL
+1 on carefully doing the pinion pre-load test at the end,
don't skip that
Old Dec 9, 2008 | 09:33 PM
Thumpper369
now i get the 15-35 with the crush sleeve right? so just slowly tighten the nut on the pinion until the preload is 15-35lbs. Now should I be more towards the 15 or 35 or should I be somewhere in the middle?
