won't go into gear?
Old Nov 6, 2008 | 02:34 PM
D*O*D*G*E's Avatar
D*O*D*G*E
Default won't go into gear?
the tranny worked when i got the truck i had to put a new motor in and all the sudden it don't wont to go into gear. it is a 95 4x4. any sugestions maybe i forgot to hook something up i don't know the ****er works ok so i am not sure
Old Nov 6, 2008 | 05:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you get the TC bolted back up right?
Old Nov 6, 2008 | 06:03 PM
zman17's Avatar
zman17
I assume you removed the radiator to do the motor swap, you got enough tranny fluid in it? Did you remove or accidentally move or hit any linkage to trans or transfer case? Maybe the transfer case is in neutral?
Old Nov 6, 2008 | 06:59 PM
dodgeguy97's Avatar
dodgeguy97
also check the linkage at the steering shaft and spray pb blaster on all the linkage joints
