mysterious radiator leak
Old Nov 11, 2008 | 08:13 AM
aliasmax's Avatar
aliasmax
Default mysterious radiator leak
Hello everyone, I have a 2001 dodge ram 1500 with a 360 cid and 97,000 miles on it with an automatic tranny. My radiator only leaks when its below 30 degrees. It leaks from the passenger side. it started last winter. I put a pressure tester on it many times and it won't show a leak. I drive 25 miles one way to work and after i park it at work or at home after work i will find a small puddle of antifreeze on the ground. It isn't much each time, maybe 8 to 10 ounces. It's driving me crazy, any thoughts on it will be appreciated. thanks.
Old Nov 11, 2008 | 09:36 AM
babyhuey6810's Avatar
babyhuey6810
Check the cap.I had a bad cap bite me a couple of days ago on a van.Checked everything,couldnt find a leak,but I could smell anti freeze.New cap solved my prob.
Old Nov 11, 2008 | 10:04 AM
aliasmax's Avatar
aliasmax
thanks for the reply but it is definitely not the cap. it is wet at the right side (passanger side) bottom of the radiator and completely dry everywhere else.
Old Nov 11, 2008 | 10:43 AM
babyhuey6810
Sounds like the gasket in between the plastic tank and aluminum core.New radiator time...or the old hated bars leak last ditch fixitall.
