whats the biggest tire i can fit
Old Nov 19, 2008 | 08:43 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Originally Posted by timidone
search the forums!!!
+100
Old Feb 2, 2010 | 08:12 PM
Lithium177's Avatar
Lithium177
Hey Guys. I have a 2001 1500 4x4. Just bought 35" tires on 15x10 rim. The tires rub really hard on the inner front fender. Do you guys have any suggestions to what I could try. I've read a 3" lift should do it, but My friends don't think so. Any ideas?
Old Feb 2, 2010 | 08:23 PM
USAF90's Avatar
USAF90
if you got a straight axle in the front then 33's would be max i would put on without a suspension lift.. clearance is my interest and specialty, but im thinkin on the off road perspective right now.. consider suspension flex, rubbing, tire pressue, load cap. EVEN HOW WIDE your tire is, not to mention if you get new wheels, gotta clear them too (theres more to a wheel then just how wide and tall) ect...
now im just yappin...
if your not hittin the trials or mud... then my opinion still stands at 33 max lol
if its independent suspension the maybe a 31 or 32.. JMO
Old Feb 3, 2010 | 01:37 AM
silver06cummins's Avatar
silver06cummins
I just got the top gun budget lift comes with coil spring spacers, rear blocks and u-bolts, and new rough country 8000 shocks for the front for $196.20, I saved on shipping because I live about 25mins from their shop lol. I havent got it on yet due to work but I think its well worth the $$ for 3" of lift...
and FWIW I run 285/75/16's on my truck and it hasnt attemted to rub the first time, but I think thats about max without a lift.
Old Feb 3, 2010 | 01:49 AM
wake's Avatar
wake
def search
https://dodgeforum.com/forum/2nd-gen...tock-rims.html
and thats just cause i created that thread that i knew about it...i didnt dare search there has to be at least 10 threads about this
anywhoo
im running 265/75/16 on my stock ride height 95 1500 4x4 and all the way left and right even at a pitch..no rubbing what so ever..
and if you wanna see how they look
https://dodgeforum.com/forum/2nd-gen...ok-inside.html
lucas
Old Feb 3, 2010 | 07:08 PM
hondarider's Avatar
hondarider
I got 35's on stock suspension. Fronts used to rub on the plastic but it wore itself in and now its fine. Really wouldnt recomend it but I got a lift coming soon.
Old Jan 21, 2012 | 02:20 PM
95ram4x4cruiser's Avatar
95ram4x4cruiser
I have a 95 and wanted to know if 35/12.5/15 would fit on stock 95 ram 4x4 EXT cab
Old Jan 21, 2012 | 02:35 PM
dlyter09's Avatar
dlyter09
Need a lift to keep from rubbing...
Old Jan 21, 2012 | 05:17 PM
Augiedoggy's Avatar
Augiedoggy
I got 35" tires and a 3" body lift..(they sometimes rub).. I'm lifting 2.5 more inches with spacers and leaf shackle lift in the rear. I suggest just putting them on before lifting if your not gonna change the gears to match.... That way if your really disappointed in all the power and mpg loss your gonna have you can take them back off and sell them or go to something less extreme...
The truck is really gonna be a dog and its going to burn up the transmission fast without gears better suited to the bigger tire ratio...
but there a few other active "lift" threads going on here explaining that already as well as hundreds in the archives...
Old Jan 21, 2012 | 09:46 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You also need about 4.5" backspacing to be spot on reduced rubbing.
