My ram won't start
Old Nov 14, 2008 | 08:03 AM
muppettrunner's Avatar
muppettrunner
Default My ram won't start
Hmph, I've tried it all I think. I have reached my capacity. I have changed the cap, rotor, crank sensor coil, wires, plugs battery and the only thing I can't be sure of is the fact that I found the leads to the cam position sensor freyed ad shorted. I did fix that , at least I separated them and put it back. I still get no spark. What next?
Old Nov 14, 2008 | 03:06 PM
stratusguy02's Avatar
stratusguy02
First things first, what vehicle are you talking about?
Old Nov 14, 2008 | 05:24 PM
Gone Fishin's Avatar
Gone Fishin
Yup^^^^^^^^
Need to know what it is first, then get any and all codes from the PCM. If the cam sensor is fried, that's serious!!!!!
Start at the beginning, let us know what it is you're dealing with, and any info you can retrieve----CODES!!!!
Old Nov 14, 2008 | 07:37 PM
jkillman's Avatar
jkillman
Make sure all the plugs are properly secured to the PCM. If loose, the egine wont make a noise. Gotta start with the obvious.
Old Mar 17, 2009 | 01:47 AM
muppettrunner
Okay guys, its a 96 ram 1500 pickup and I've replaced the crank sensor which was the only code I was able to retrieve back when it ran last. BUT I tried to buy a CS from Autozone for the Standard (5 speed) that it is. They geve me one with the wrong clip on the wire. So I returned it and got one that fit the wire, It was from a 2000. Then I find out that they don't stock the one for the standard trans. So now I have 3 crank sensors, two of which are the same legth and one is longer, but only one fits the wire clip. How can I tell which one is it?
