lost my brakes and my poower steering
Old Nov 16, 2008 | 08:40 PM
FIREBUG13's Avatar
FIREBUG13
Default lost my brakes and my poower steering
I lost my brakes and my poower steering i put a new power steering pump on it and a hydraulic brake booster and it still did not fix it can you help thank you 1999 Dodge 3/4 ton 4+4 Diesel
Old Nov 17, 2008 | 05:16 AM
bigster's Avatar
bigster
that's strange, they have fully separate circuits... what happened in the first place, did they fail at the same time?
Your brakes are working with vacuum, check the vacuum hose that goes to the brake booster. Also if you changed the brake master cylinder then you'll have to bleed the brakes to eliminate all air from the system.
For the p/s pump, the accessory belt is installed? enough fluid in the pump? Does the wheel of the pump turn when you start your engine?
I'm just guessing, give us a little more facts about what happened before and what you actually did to try to fix it.
Greetz,
Bigster
Old Nov 17, 2008 | 07:53 AM
FIREBUG13's Avatar
FIREBUG13
yes I lost them both at the same time. they do not run off a belt it runs off the timeing gear. they both run off the power steering that runs off the vacuum pump (yes i still have vacuum) that runs off the timeing gear i put a new power steering pump on it and a hydraulic brake booster . thank you for the heip
