heat???
Old Nov 17, 2008 | 11:47 PM
encorejc35's Avatar
encorejc35
Default heat???
im up here in michigan and for some reason my heat seems to suck! any ideas why my heat isnt working fully? the a/c also isnt working and hasnt for awhile now, thanks, jesse
Old Nov 18, 2008 | 07:27 AM
dhvaughan's Avatar
dhvaughan
check temp gauge/t-stat, replace t-stat if its not sitting on 195 or so. backflush heater core in both directions, ensure full flow. when running check both heater hoses. they should both be way too hot to hold. check your heat control which operates the blend door, it should rotate from cold to hot and move the door. the door is hidden. check that blower motor is running.
this is the service manual for an 01, but its very similar.
https://dodgeforum.com/forum/2nd-gen-ram-tech/41924-merry-christmas-guys.html
there's a couple more similar posts running about the blend door. follow those.
Old Nov 18, 2008 | 01:51 PM
talon6's Avatar
talon6
check and make sure your antifreeze is topped off.low anti means no heat.and.......................................... ......GO BUCKS!!!! lol
Old Nov 19, 2008 | 12:08 AM
encorejc35's Avatar
encorejc35
my thermo temp stays at 195 and doesnt ever go any higher, how would i go about trying to see if the heater core flows in both ways, i have no idea how to work on heat or a/c, im not leaking coolant and i cant tell if its full or not, i may be burning it but i doubt it. im thinking about checkin the blend door, which i think is that dial above the blower speed, how do you check it? thanks alot guys
Old Nov 19, 2008 | 12:10 AM
encorejc35's Avatar
encorejc35
hey guys, im also throwing a code now, egr valve, i think maybe this could have something to do with it, vacuum wise
