No Idle... Vacuum Leak?
Old Nov 19, 2008 | 04:05 AM
pei09's Avatar
pei09
Default No Idle... Vacuum Leak?
2001 Dodge Ram 4X4 5.9L
I didn't drive my truck for one day the next day I get in and it won't idle. Starts up and if I give it gas it will run but when I let it down to idle it dies. I think it is a vacuum leak. Could it be my pcv valve? Anyone else run into this problem?
Thanks Any Imput is greatly appreciated.
David
Old Nov 19, 2008 | 05:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove and clean the IAC. Look in the DIY section for a how to.
Old Nov 19, 2008 | 07:22 AM
dhvaughan's Avatar
dhvaughan
remove and replace the IAC. the little bastards frequently fail.
Old Nov 19, 2008 | 08:10 PM
rmiller's Avatar
rmiller
Get some throttle body cleaner and use it following the directions and see if that helps. It has worked for me on a couple occasions.
Old Nov 19, 2008 | 08:21 PM
aim4squirrels's Avatar
aim4squirrels
You IAC (Idle Air Controller) has failed in the closed position and will not allow air to pass to maintain idle combustion. When you step on the throttle, you open the throttle plates and air can get in. No throttle=closed plates=no air=no combustion.
The IAC is located on the back side if the throttle body and is held on by 2 #25 torx screws. Roughly $40 and 5 minutes to replace.
Old Nov 19, 2008 | 09:06 PM
Deviantblis's Avatar
Deviantblis
Yep it was the IAC valve for me as well!!
