Seat Connector Pinout
Old Nov 20, 2008 | 11:53 AM
knicelyr's Avatar
knicelyr
Default Seat Connector Pinout
Hello,
I've swapped the seats in my 1999 dodge ram and my 2001 dodge ram. The connectors are different, I know i should have checked that...
I need to get the power seats working on both and the seat belts from the 1999 swapped to the 2001 will not come out.
I've been told there is a contoller in the mid section that needs to be powered.
If I had the pinouts for both seat connectors i think i could work it out.
Thank you,
Rick
Old Nov 20, 2008 | 06:26 PM
froesen's Avatar
froesen
I don't have the pinouts for those years, but there is a solenoid in the seat belt retractor that needs to be energized before the seatbelt can be pulled out. It is energized by the seat belt module which is the black box underneath the middle seat. If you still have that module plugged in, but don't have the drivers seat itself plugged in, your seatbelt won't come out.
Old Nov 21, 2008 | 01:10 AM
Diefenbaker's Avatar
Diefenbaker
check this site for connector pinouts: http://dto.vftis.com/mopar/disclaimer.asp
Old Nov 21, 2008 | 07:47 AM
knicelyr's Avatar
knicelyr
froesen,
Do you know how I can find pinouts?
Will another year work? The most important one is the 1999. The 2001 only has 3 pins.
Is the seat belt indicator just energized or is it some computer voltage?
