Suspension Help.
Old Nov 20, 2008 | 11:53 PM
chet's Avatar
chet
Default Suspension Help.
I am looking for like 3-3.5'' coil spacers and like 2-3'' Add-a-leaf. That should make my truck fairly level if i can get 3'' of both or 3'' rear and 3.5'' or so in the front. But ive looked and SEARCHED and i cant find anyone who makes a 3'' coil spacer i thought i had seen one before so if someone could post a link where to the coil spacers and what add-a-leafs are good i would much appreciate it.
Old Nov 21, 2008 | 09:57 AM
Aubrey's Avatar
Aubrey
I've only ever heard of a 2" spacer for the coils. Add-a-leafs are mostly by height so I wouldn't worry so much about brand for that.
Old Nov 21, 2008 | 10:55 AM
dodgeram07's Avatar
dodgeram07
i know your wanting 3-3.5"spacer, but the only one's i found were 2"... have you thought about getting tall springs? the 2500 V10's spring( https://dodgeforum.com/forum/showthr...hlight=springs )look like they about/allmost do what your wanting... they were 100-110 dollars at http://rockauto.com/ if i was looking at right ones......just thinking of a little diff way of trying to do the same thing..hope i helped
Old Nov 21, 2008 | 06:50 PM
chet's Avatar
chet
wonder how much lift the springs would give. $100 for a pair isnt bad, id like to get atleast 3'' wonder if i could add the spring if it gives say 2.5'' and a 1 or 1.5'' spacer(i thought i saw someone with one on here, but i may be wrong again.) Do add-a-leafs come in different lifts or the same ?
Old Nov 21, 2008 | 06:56 PM
chet's Avatar
chet
also i have an offroad which is suppose to sit 2.5'' higher or so. Do you think i already have the 2500 springs, is that how the factory did it ?
