Starter Noise?
Old Nov 22, 2008 | 08:51 PM
geekydude's Avatar
geekydude
Default Starter Noise?
Hello all. I have noticed that when I start my truck when it is cold it cranks fine but makes a buzzing/wheezing noise before turning over; it seems to be coming from the starter. I just changed the battery, cleaned the posts, changed the plugs, wires, cap and rotor. When the truck is warm, it starts fine. The truck has 150K, so I am guessing the starter might be going bad. Anyone have ideas on what do? Has anyone experienced this same problem? Thanks for your reply.
Old Nov 22, 2008 | 11:27 PM
lastrights's Avatar
lastrights
starter man, same thing to mine, took it apart and i rebuilded it . bought the rebild kit on ebay for 30 bucks, instead of buying a new one for 350. put it in started awesome. no problems now , but yeah it is your starter.
Old Nov 23, 2008 | 02:00 AM
Laramie1997's Avatar
Laramie1997
I wouldnt mess with rebuilding the starter that you have... You can get a rebuilt one at oreily's for like 30 provided you give them the old one back
I did that on mine about 5 years ago and havent had problems out of it yet
Old Nov 23, 2008 | 07:49 AM
lastrights's Avatar
lastrights
it was a pain in the azz yes but saved decent money , the guy i bought the rebuild from sent new thicker metal and a plumber, should be good to go. oh and the top bolt is a pita to get off
Old Nov 23, 2008 | 08:11 PM
geekydude's Avatar
geekydude
Guys, thanks for the info. Changed the starter, not a big deal. Sprayed some lube on the bolts, let them soak for a bit, and used breaker bar. Bolts came off easy. So far no more noise, which is good.
