knock sensor
Old Dec 24, 2008 | 01:32 AM
  #21
vmann's Avatar
vmann
30 bucks? no thanks. that is way too much money. Its alot when you are $-400 =[
Old Dec 25, 2008 | 02:13 PM
  #22
skolle's Avatar
skolle
new plugs, wires, plentum gasket, cat
Old Dec 25, 2008 | 08:00 PM
  #23
hutch1973's Avatar
hutch1973
Does a code reader give you anything different then just using the key switch off/on 3 times?
Old Dec 26, 2008 | 08:19 AM
  #24
JimkDaAdtman's Avatar
JimkDaAdtman
Great Question, Let s see what the Experts have to say, PurplDodge? Anyone?
Old Dec 26, 2008 | 08:48 AM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
Depending on which one you buy, they do give you info about the codes also. And not only that , but they work on a multitude of various vehicles, and IIRC 98 and up rams will not give codes with the key on/off check.
Old Dec 26, 2008 | 11:34 PM
  #26
hutch1973's Avatar
hutch1973
What's an IIRC 98 and up ram? Works on my 01, is it a different system?
Old Dec 27, 2008 | 07:16 AM
  #27
zman17's Avatar
zman17
IIRC = If I Remember Correctly and 98 and up ram= 98 and up ram.
Anyway, maybe it just doesn't work if it doesn't have any codes to show. Either way, I have an expensive scanner, but I have tried the key method even with a CEL and it didn't do anything. But, If it works on Hutch's 2001 I must be wrong and thinking of a different vehicle.
Old Dec 27, 2008 | 10:27 AM
  #28
hutch1973's Avatar
hutch1973
Oohh, ok. I was trying to be smart, I found the key method via search on here 2 weeks ago when I had a check engine light. Know nothing about it outside of it worked great.
Doesn't mean the truck is fixed, but babysteps.
Old Dec 31, 2008 | 10:58 PM
  #29
skolle's Avatar
skolle
it was the map sensor
Old Dec 31, 2008 | 11:09 PM
  #30
dodgeram07's Avatar
dodgeram07
thanks for the reply... alot of people don't tell us what the problem was. thanks
