Stupid question - Chking xmission fluid
Old Nov 25, 2008 | 02:57 PM
ophidia's Avatar
ophidia
Default Stupid question - Chking xmission fluid
I didn't get a manual with my truck-- do you check it in park or neutral? In park I show a high level, in neutral it's spot on.
Thanks
Old Nov 25, 2008 | 03:53 PM
charlie1935's Avatar
charlie1935
In neutral is the right way.
Old Nov 25, 2008 | 04:05 PM
Mike Roma's Avatar
Mike Roma
Yeah, mine says to check when "hot, idleing in neutral".
Yours doesn't say anything on the stick?
Old Nov 25, 2008 | 04:07 PM
ophidia's Avatar
ophidia
Thanks guys.
I didn't even look on the stick itself... I'll have to check it out.
Old Nov 25, 2008 | 05:04 PM
Ram2K1's Avatar
Ram2K1
Some have a cold and hot mark on the dipstick, but I think the Rams only have a hot...
Old Nov 25, 2008 | 08:24 PM
MonteC's Avatar
MonteC
When in park there is no cooler flow or lube flow. The PR valve just dumps all of the fluid that is being pumped right back into the pan so the dipstick will read high. When in neutral or any other gear cooler flow resumes as well as lube flow, now more fluid is being directed elsewhere, lowering the amount of fluid in the pan.
Old Nov 26, 2008 | 09:34 AM
ophidia's Avatar
ophidia
Cool. Thanks guys.
