Weird stereo problem
Old Nov 26, 2008 | 02:16 AM
BigDubDiesel's Avatar
BigDubDiesel
Default Weird stereo problem
Alright so here's my problem I installed two eclipse 6x9 speakers in the door, two polk 5 1/4 in the rear, and a panasonic deck. Now here's where it gets weird once I got everything installed, when I have the radio on everything works perfect but once I turn on either a CD or use the inputs only the rear speakers and the tweeters work. My truck is a 98 ram with the infinity system stock. I can't figure out why it does nor have I ever heard of a similar problem. i would appreciate any input as it's pretty annoying that I can't have the system to its full potential I don't know if it's internal to the deck or if it has something to do with the original infinity system currently I have the amps just hanging behind the speakers in the door, but it doesn't make sense that it'd all work for the radio but not the CD or input's. Thanks for any help.
Old Nov 27, 2008 | 04:21 PM
priest1981's Avatar
priest1981
Sounds like you connected the power antenna wire and not the remote amp wire from your deck. Check to see if your deck has another wire marked remote or amp and connect it to the wire your that you have the power antenna wire to, that should fix the problem.
Will
