Replacing Belt
Some cars have an arm that sticks out with a hole that a 3/8" or 1/2" drive ratchet (or other designs) will fit into. Our Rams(and some other vehicles) you can simply put a socket on the pulley bolt to release the tension. And speaking of tension, I bet you two would get along great if you met each other and had a beer together. :-)
And BTW VMANN! Since I'm acting like the Fatherly type right now, read/listen and learn before you keep making posts about things you know nothing about.
Damn! I jest learnt sum'thin' new. Thanks kid.
You can do it. Working on these trucks is a snap. The Haynes manual is actually pretty decent.
A Haynes manual is only like $20, not $35. And you can also download the FSM here for free. http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
That's the best place for ordering parts. I think I paid $20 for my manual. Make sure you order over $100 worth of parts each time to make it worth your while.
