Tight throttle or maybe loose? I really don't know
Old Nov 27, 2008 | 09:19 PM
guitarking135's Avatar
guitarking135
Default Tight throttle or maybe loose? I really don't know
Ok I bought this truck with alot of problems but I got it cheap so I can't complain so right now
my accelerator has like 1/4 inch then its at the floor. and in addition to this it is really stiff. any ideas what it could be?
Old Aug 4, 2009 | 08:59 AM
wildcat50's Avatar
wildcat50
Sounds like the same problem I am having. There is alot of play in the accelerator pedal. Also its hard to press down when accelerating. Did you figure this issue out?
Old Aug 4, 2009 | 01:05 PM
CSXfan's Avatar
CSXfan
Look at where the throttle cable connects to the throttle body. Sounds like the cable isn't routed properly. The cable should rest in a little curved channel on the butterfly shaft. If you don't know what I'm talking about I can take a picture of it and post it later tonight.
Old Aug 4, 2009 | 09:10 PM
dhvaughan's Avatar
dhvaughan
^ +1. sounds like your throttle cable is on the wrong side of the guide. top or bottom i can't remember. i connected mine up wrong like that one time. pedal was very stiff and had very little travel. i'll look for a pic.
edit - can't find one. anybody else got one?
Old Aug 4, 2009 | 11:11 PM
CSXfan's Avatar
CSXfan
Here ya go...
Old Aug 5, 2009 | 08:28 AM
wildcat50's Avatar
wildcat50
Thanks guys. I checked and my cable is routed correctly as in the picture you posted. I pulled on the cable a few times, moving it around and now the gas pedal is no longer hard to press down. Perhaps the cable was bound up somewhere. Before it was really hard to press down and my truck didn't have much power and would take forever to get up to speed. It still has alot of slack in it, however. My mechanic said that it looks like the cable is worn out and has been stretched. You think I should bother replacing it? I saw a posting on here where you can use a fuel line and some clamps as spacers to take up the slack. Thanks again for the replies and the picture.
Old Aug 6, 2009 | 05:15 AM
speeddemon31176's Avatar
speeddemon31176
Buy a new throttle cable for 15 bucks and call it a day. If you rig it up and it sticks wide open you will regret rigging it immediately. I just did mine a few months back due to fraying and it made a world of difference. I wouldn't want to have the responsibility of knowing I killed someone because I was too cheap to replace such a cheap part.
