changeing blot pattern
Old Nov 30, 2008 | 11:28 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Default changeing blot pattern
i have a o1 ram 1500 reg.cab 4x4 5.9l w auto trans can i change the number of blots from 5 to 8??
Old Dec 1, 2008 | 03:30 PM
sungod's Avatar
sungod
Sure, just go down to your local junk yard and pick up a new front and rear axle. Get a torch, welder, and some spare time an you are set.
Old Dec 1, 2008 | 03:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You"ll need a donor truck to change the BLOT pattern. LOL
Old Dec 1, 2008 | 03:48 PM
Silver_Dodge's Avatar
Silver_Dodge
I didn't even know my truck had blots. I better check them. Do you have to grease them or something? Is there a blot upgrade that would give me more HP and better mileage at the same time?
Old Dec 1, 2008 | 04:28 PM
zman17's Avatar
zman17
Only if you keep it waxed!
Old Dec 1, 2008 | 06:27 PM
Ibleedmopar's Avatar
Ibleedmopar
Sorry Im changing the subject from Blots. What is the Bolt pattern size for my 98 half ton. Ive been told it is the same big pattern 5 on 5.5" as they used to be and that they are 5 on 5". Thanks Eric
Old Dec 1, 2008 | 06:37 PM
PurplDodge's Avatar
PurplDodge
Ram 1500's have the 5 on 5.5'' bolt pattern. If you want the larger 8 lug, you would need front and rear axles from a 2500/3500 Ram. You would also need 8 lug wheels.
Old Dec 1, 2008 | 11:07 PM
dodge15004x45.9
thanks i get the POINT and was just checking
