tranny issues
Old Dec 3, 2008 | 07:41 PM
SinfulDragon's Avatar
SinfulDragon
Default tranny issues
Ok so I have some issues with my trans.
If I go slow everything is just perfect however if I try to accelerate at even moderate speeds then it doesn't wanna shift out of 1st gear (will redline and stay there until I let off the accelerator) and when it does shift it wants to keep falling back into 1st.
Please tell me this sounds like a simple problem to fix. I have a shop that isn't too far away that will do basic testing for free but anything more than "basic" and it starts costing $$ so I haven't taken it there just yet.
Old Dec 3, 2008 | 09:30 PM
TheForce55555's Avatar
TheForce55555
Its probably going to die sooner or later, so maybe change the fluid and add little lucas tranny juice and that might straighten it up, I have been through 2 trannys in my 2nd gen, its likes to eat them about every 20,000 miles
Old Dec 4, 2008 | 08:42 AM
SinfulDragon
Did you forget a 0 in there, I have just over 200K on this truck and the tranny has just this past year started acting up.
Old Dec 4, 2008 | 12:44 PM
MonteC's Avatar
MonteC
First off, dont put lucas in the transmission.
Sounds like you need to do a service and change the Governor pressure sensor and solenoid.
Old Dec 4, 2008 | 01:47 PM
Dodgeman000's Avatar
Dodgeman000
Sounds like a bad speed or load sensor.
Old Dec 4, 2008 | 04:48 PM
7mmmag1's Avatar
7mmmag1
might have the bands adjusted also
Old Dec 4, 2008 | 08:50 PM
wadbuc54601's Avatar
wadbuc54601
MonteC
__________________________________________________ ___________
I had the same trouble cost about 400 bucks for governor pressure sensor and solenoid. That was at a local shop.
Old Dec 5, 2008 | 06:07 AM
MonteC's Avatar
MonteC
Yeah shops mark those two solenoids WAY up. Its better to buy them yourself and take them to someone or do it yourself.
Old Dec 5, 2008 | 06:39 AM
BULLRAM's Avatar
BULLRAM
Sinfull.........you need to have a scan tool put on it and have the govener pressure checked, to make sure there in NO voltage at the pressure sensor at idle or at a stop, if you cant get that, remove the pan, then look at the right side of the valve body, you will see a round topped valve sitting in a metal shroud, remove just the torx bolts, holding that small plate, then a few regular bolts, also holding it on, then it pulls straight out, when you get it out you probably will see all the GUNK , built up on the GOVENER SOLENOID screen or filter if you will, dissconnect the plug, and spray it off with brake clean,you will then see the filter is supposed to be white or clear........put it all back in and refill the tranny, it should now shift good, if not then you probably have more serious problems, but this takes car of 90% of the WONT SHIFT.PROBLEMS, AND ALSO THE ..STARTS OFF IN SECOND GEAR PROBLEM, try it out and good luck
Old Dec 9, 2008 | 11:51 AM
SinfulDragon
Thanks a lot!!! I'll give that a go and let everyone know how it works out.
