Help!! truck stalls at low RPM's
Old Dec 4, 2008 | 01:08 PM
cuaco_ortiz's Avatar
cuaco_ortiz
Default Help!! truck stalls at low RPM's
Hi guys, please lend me a hand if you can!
My truck started stalling after I took the battery off from my truck to jump start my wife's expedition. When I took the positive terminal off from my truck's battery, I accidentally touched the truck's brake pump and sparks flew (I imagine I discharged the computers and other accesories power).
When I connected the battery back onto my truck, I could not start my truck as fast and easy than it was before, it took several crankings, but it finally started. From this moment on, my truck stalls at low rpm's (when coming to a complete stop).
What can I do? please advice...
thanks...
Old Dec 4, 2008 | 02:09 PM
bigster's Avatar
bigster
Take the negative cable off the battery and wait 10 minutes, reconnect and try again. Also, check the vacuum tube that goes under the battery tray for the cruise control, i had the same problem and you can't see it, you'll have to go by feel or take of the battery tray (i did it by feel and took me 1 minute to reconnect).
Hope this helps!
Greetz,
Bigster
