Heated mirrors broke?
Old Dec 10, 2008 | 11:47 PM
01DodgeRam1500's Avatar
01DodgeRam1500
Default Heated mirrors broke?
First i want to say that this forum is extremely helpful when it comes to almost anything dodge related. Second, to the real issue, im not much of an electrician and i need help with the rear mirror defrost. i don' t know if it works or not. i read the manual here on the site and cannot make heads or tails of it. when i press the button the "indicator light" for the defrost system comes on, but i cannot see ant noticeable difference in the amount of ice on my mirrors.
Thx in advance for everyones help
Old Dec 11, 2008 | 03:00 AM
Dodgeman000's Avatar
Dodgeman000
First start with the basics. Check the fuse. Check all of them, its really easy with a meter. You can get one from walmart for $25 bucks. If your fuses are good check for voltage at the switch. If you have voltage, check the switch. If the switch is good then your chasing wiring.
Old Dec 11, 2008 | 04:25 AM
jasonw's Avatar
jasonw
Site Moderator
How long have you waited to see a difference? Mine usually takes at least a couple minutes, sometimes closer to five if its really cold out, before the ice/frost/snow starts melting off of mine.
Old Dec 11, 2008 | 08:19 AM
01DodgeRam1500
i drove 15 minutes to school with it on sometimes and i see no difference, but the timer does turn it off, i know, if im not mistaked,that i have voltage at the switch because the light comes. is there a fuse in the cab because i read the panel and didnt see what i think would be a fuse for it, which fuses would it be for the defrost???
