misfire
Old Dec 13, 2008 | 12:16 PM
360dodgeram360's Avatar
360dodgeram360
Default misfire
my 98 ram shows a cylinder 4 misfire. It was quite noticeable when i first start it up and it shakes but once its warmed up it doesnt seem quite as bad. I replaced the plugs, wires, cap and rotor still the same problem. I used 2 bottles of fuel injector cleaner also. Nothing made a difference. As a last ditch effort i even replaced the #4 injector with one from a 318 ( i know these are probably different but wanted to see if there was a difference in how it ran and if it was completely blocked) Also i didnt want to throw money at it for new injectors when i had the 318 injector just laying around. The only thing i can think to do now is a compression test. any other ideas?
Old Dec 13, 2008 | 12:50 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Start with the compression test because you need to evaluate the engine's condition anyway. After that, perform a leak down test on your #4 to see if it's leaking and if so, where it's leaking.
Old Dec 13, 2008 | 12:54 PM
360dodgeram360
how do i perform a leak down test?
Old Dec 13, 2008 | 01:04 PM
Rex-TheDOGG
I posted a procedure on this thread:
https://dodgeforum.com/forum/2nd-gen...misfire-6.html
Old Dec 13, 2008 | 01:32 PM
360dodgeram360
alright i will see what i can do, right now i'm away from my truck but when i get back in town i'll do the tests.
