creeking in front end
Old Dec 15, 2008 | 01:49 AM
cdusthockey's Avatar
cdusthockey
Default creeking in front end
ive noticed the sound a few times when im at the drive thru at a restaurant, it sounds like a metal creeking sound, and i cant find it. it only really seems to do it when it is cold outside (lower than 10degrees) just wondering if anyone has experienced this problem
Old Dec 15, 2008 | 02:07 AM
hjworth's Avatar
hjworth
Hello, this is my first reply so hope I do it right.......my 98 2wd 1/2 ton used to do that....ended up replacing the ball joints and it cleared it up......almost drove me nuts trying to find out the cause....hope this helps
Old Dec 15, 2008 | 04:44 AM
OldMoparMan's Avatar
OldMoparMan
In my truck, It ws my balljoints.... Same dry, metal on metal screaching noise.....
Old Dec 15, 2008 | 09:54 AM
Aubrey's Avatar
Aubrey
Could be brakes dragging or a u-joint.
Old Dec 15, 2008 | 01:04 PM
tazman6789's Avatar
tazman6789
could be a tie rod end also, try having someone turn the wheel back and forth slowly while u put ur hands on the diff parts see if u can feel a grinding on the part
Old Dec 15, 2008 | 02:50 PM
BULLRAM's Avatar
BULLRAM
When its cold outside try pushing down and release the left or right front fenders at the tire, it is usually the ball joints,
Old Dec 29, 2008 | 07:08 PM
relic46's Avatar
relic46
My stabilizer shock creaks like crazy. I lube it with lithium grease and it stops for a while.
