No heat in cab to little heat in cab.
Old Dec 16, 2008 | 09:21 PM
Hoogie's Avatar
Hoogie
Default No heat in cab to little heat in cab.
1998 ram 1500 with a 360. When it got cold i was getting no heat in the cab. Changed thermostat and now i only get heat when my engine is at 2000rpm or higher. When i stop at a red-light or drive at highway speed with low RPM i get no heat. The fan blows at same speed and the difference in temp change is almost instant. Any help would be greatly appreciated.
Old Dec 16, 2008 | 10:46 PM
guitarking135's Avatar
guitarking135
flush your heater core BOTH ways and see if you have a difference I know its kinda cold to do but you may try to do it in a garage or something. IF your at the light and you rev your engine to 2000 rpms does it get hot again? if so you may have a water pump thats going out on you.
Old Dec 16, 2008 | 11:18 PM
TheForce55555's Avatar
TheForce55555
+1 water pump
Old Dec 17, 2008 | 12:00 PM
sungod's Avatar
sungod
You could try your water pump, but if you seach this forum you will see many posts of people with little heat. I have replaced my thermostat and water pump as well as flushing the core several times and still very little heat.
Old Dec 17, 2008 | 12:26 PM
dodgeram07's Avatar
dodgeram07
a weak radiator cap can cause the problem, because it will not build up pressure... you can take it to autozone and they will test the cap for FREE ( at least the one up the street from does)....... just a thought
