no heat mystery diagnosed?
Old Dec 18, 2008 | 03:57 PM
dodgeforlife15's Avatar
dodgeforlife15
Default no heat mystery diagnosed?
turns out i have a coolant leak. i noticed it this morning when i was adding coolant for the second time in two weeks. it looks to be coming from the area where the water pump is... i think. it is coming from the bottom front of the engine just behind the lowest pulley. do you guys know where the leak may be from and how should i go about fixing it? also could this be the reason why i have no heat in the cab?
Old Dec 18, 2008 | 05:07 PM
dodgeman22's Avatar
dodgeman22
it could be why your getting air in the system which could be why your getting no heat and the best way to fix it is to change your water pump
Old Dec 18, 2008 | 07:06 PM
peterl23452's Avatar
peterl23452
Default water pump
i replaced the water pump on my cousins 2nd gen....there is a small riser tube on top i recall which was very corroded...could be leaking there and running down. or it could be the water pump itself...cant remember if the 2nd gen had em but most water pumps have a weep hole on the bottom{directly below the pulley} that is designed to leak before the pump fails.. good time to replace your thermostat as well
edit: the heater cores are known to go on these trucks... fix the pump or leak first then try your heat
if its your heater core prepare for a big job {you have to pull the dash and possibly discharge your ac}
i have not heat as well{ core is bypassed cause it leaks} will replace this winter though it's getting cold in VA} not to mention if i do have top lose my ac i dont want to do that in the summer..
i would rather not have heat in the winter then no ac in summer--depending on local climate
