stalling problem
Old Dec 22, 2008 | 09:54 PM
dodge74's Avatar
dodge74
Default stalling problem
I have a 2001 Ram 1500 with the 318. Truck stalled and wouldnt restart. Figured out the coil wasnt getting a spark, so I replaced it and then after truck was out plowing for about an hour and a half it started stalling again when put into reverse. Truck will stay running if you give it gas. What do you think is the problem
Old Dec 22, 2008 | 11:03 PM
dhvaughan's Avatar
dhvaughan
my guess would be either the idle air control (IAC, about $50, on back of throttle body) or throttle position sensor (TPS, about $40, on drivers side of TB). i use to blame idle problems on IAC, but my latest round turned out to be TPS.
