94 dodge ram problems
Old Jan 5, 2009 | 07:43 AM
miller2josh's Avatar
miller2josh
ya. i have the same problem with mine. my gas gauge dont work either. so i have to fill it up about every 200 miles. im going to be checking things out today. ill let u know what i find out.
Old Jan 5, 2009 | 07:51 AM
Mudbone25's Avatar
Mudbone25
do you run out of gass often.. I do everonce in a while and i was thinking it might be a cloged fuel filter since it stirs up all the crap at the bottom of the tank.
Old Jan 5, 2009 | 09:07 AM
miller2josh
ive never run out of gas. did u still have gas in ure tank when u ran out of gas? and if so, how much?
Old Jan 5, 2009 | 05:35 PM
miller2josh
well guys. it never fails. i go to check the fuel pressure and our fuel pressure gauge at work, the attachment i needed, the shcrader valve in it was broke, n i couldnt use it. so i wasnt able 2 check the fuel pressure. but i did put the scanner on my truck today. everything showed up normal. i didnt find anything that was out of wack. but i still had the noise and everything going on. i think its a lean condition. and. another thing i forgot 2 mention. when i stop at a redlite, or stop sign, when my truck is warmed up. n the engine speed slows down to an idle. the engine speed drops way down when im stopped, like it almost wants to quit. then the engine speed goes back up to normal. it only last about 2 er so seconds, only when i stop. would that possibly a cat problem?
Old Jan 5, 2009 | 06:38 PM
Mudbone25's Avatar
Mudbone25
when its done it for me i wind up putting between 19- 22 gallons in. and i have run out a bunch of times where im practly costing to the gas station... its uasally when my dad fills the tank and forgets to reset the trip.
Old Jan 7, 2009 | 09:33 AM
miller2josh
well. i still didnt get anything checked out on my truck. yesterday we were really busy. and. as i drove my truck. i had it warmed up and everything. i could not get my truck to what it was doing before. the pinging and all that. it ran fine. no loss of power what so ever. i did buy some lucas oil upper cylinder lubricant yestrday to put in my truck my next fill up. it supposedly cleans everything. so i jsut figured i mite as well try it. but otherwise. it was running good yesterday.
Old Jan 12, 2009 | 12:10 PM
miller2josh
My truck has been running fine for about a week now. it hasnt made and noise or had a loss of power. i dont no what the deal is. but its runnin perfect now.
