Tail Pipe size ??
Old Feb 17, 2005 | 01:01 PM
mope's Avatar
mope
Default Tail Pipe size ??
am going to run a single in dual out muffler on my truck. I have read many threads debating the best size to run. My question is this: Should I run 2 1/2 or 2 1/4 dual tailpipes? My truck has the 5.9. Have any of you that have the dual 2 1/2 tailpipes lost any low end?
Thanks
Old Feb 17, 2005 | 01:29 PM
steve05ram360's Avatar
steve05ram360
Default RE: Tail Pipe size ??
yes they do, that's why you should go with 2.25's
I speak from experience on my truck with the 5.9 liter motor
Old Feb 19, 2005 | 09:41 PM
wildthing4870's Avatar
wildthing4870
If you are running dual pipes after your muffle shouldnt matter what siz you put on, you could out dual 4 inch if you wanted. All the pressure is gonna fter it exits the muffler. Personelly i run you single 2 and a half in and then 2 and a halfs out, personelly i like bigger rears, but i dont like to loose my power, pretty sure stock its 2 and a half right. Drop some headers in go to 3 and then 2 and a half out.
Old Feb 21, 2005 | 08:23 PM
steve05ram360
I disagree... my own experience tells me that if your dual outs are too big, you'll loose backpressure and low end torque. I experimented with mine and found that 2.25" dual outs is pretty close to a 3" single out and performes good.
