Popping Noise ---Need Help
Old Feb 17, 2005 | 11:03 PM
hellraiser6's Avatar
hellraiser6
Default Popping Noise ---Need Help
I have been noticing a popping noise that feels like it is coming from the rear end. I only notice it at speeds slower then 10mph. It only does it ever so often, not a constant pop. Kinda feels like a bad tooth on a gear. Anyone experience this problem, please help.
Old Feb 17, 2005 | 11:25 PM
greeny's Avatar
greeny
Default RE: Popping Noise ---Need Help
whats up. You might need to add more diff lube. That happened in my boss's dodge and that fixed it right away
Old Feb 18, 2005 | 06:21 PM
P.B.'s Avatar
P.B.
Does it have a locker? If so maybe the clutches aren't slipping the way they are supposed to. Check and be sure the fluid level is full like greeny said first.
