surge at idle
Old Jan 10, 2009 | 12:26 AM
dakotas ram's Avatar
dakotas ram
that doesnt have anything to do with part-throttle does it?....seems like it does it alittle then too....not very much at all tho
Old Jan 10, 2009 | 11:03 AM
Ram2K1's Avatar
Ram2K1
If it does it at part throttle, check your TPS.
Old Jan 10, 2009 | 11:19 AM
dodgeram07's Avatar
dodgeram07
you can do a volt sweep on the tps.
Old Jan 10, 2009 | 03:10 PM
tailhunter's Avatar
tailhunter
i have a 98 dodge ram with a 5.9. my problem is that when i first start it, it runs fine, but if i shut if off and then restart it, it will fire up but then die right away, if i give it gas it will run fine, its just when i let off the gas then it will die. i have replace the coil on the truck several times before because moisture was getting in it. any help?
Old Jan 10, 2009 | 03:33 PM
dakotas ram
sounds like your idle air control is closing and staying closed when you kill it for some reason
Old Jan 10, 2009 | 06:41 PM
tailhunter's Avatar
tailhunter
Do you think if i sprayed some carb cleaner in the intake that it will free it up, or do you think it is the TPS?
Old Jan 10, 2009 | 07:45 PM
dodgeram07's Avatar
dodgeram07
you can clean the iac with some carb cleaner... take it out you the tb and clean it
Old Jan 11, 2009 | 01:21 PM
tailhunter's Avatar
tailhunter
where is it located and how do you take it out?
Old Jan 11, 2009 | 11:16 PM
dakotas ram
the iac is the thing you see in the bottom left corner(red circle)....this is one already cleaned....yours will probably be black and crusty......its located on the very back of the tb(arrow)....the blue circle is where the air is actually coming in at and the IAC moves in and out to control it
Old Jan 12, 2009 | 09:54 PM
tailhunter's Avatar
tailhunter
Thank you very much for your help. i will try that and hopefully it works. Although i wont be able to get to it until this weekend. The truck is parked outside and we are currently having a blizzard right now.
