Trans pan drain plug!
Old Jan 12, 2009 | 06:09 PM
  #31
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by hometheaterman
http://www.amazon.com/B-80250-Automa...1774464&sr=8-1
That's what I got I'm pretty sure although it's not purple as in the picture. It's cheaper a few dollars cheaper than $10 which is what you said it was at Geno's Garage.
I don't know if you'd call it a o-ring but it has that white rubber piece that's like a gasket or washer or whatever you want to call it. I think that's the only thing on it. Not sure if it has one anywhere else but I don't think so.
See that one is better because the small drain plug is pipe thread, if you look at the pics DVaughn posted , you can see a small black o-ring that seals when you tighten the plug, which is what I have. If I tighten it any more then finger tight the o-ring slides off the sides of the head, and it is not pipe thread.
