ABS and e-break lights
Old Jan 10, 2009 | 04:49 PM
WillTX's Avatar
WillTX
Default ABS and e-break lights
i have a 98 1500 3.2 and every now and again i get the abs and e-break lights on my dash. any suggestions as to what may be causing them to come on?
Old Jan 10, 2009 | 05:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove and clean the electrical connector on top of the rear diff.
Old Jan 10, 2009 | 06:04 PM
Kindschi's Avatar
Kindschi
Check and see if your Speedomter works at low speeds (under 20mph) if it does not and then the brakes lights come on when it begins to works it could be the rear speed sensor located on the top of the rear differential. 15 dollar part from the dealer, took 5 mins to change.
