backwards jumper cables
Old Jan 12, 2009 | 11:32 AM
rfm6762's Avatar
rfm6762
Default backwards jumper cables
My son has a 98 ram I belive he hooked the jumper cables up backwards
while trying to jump start it ,we did get it stated and replaced several
fuses,only 2 problems left battery does not seem to charge (put new battery in after cables hooked backwards) I assume the alt. is fried
and will have to be replaced (not to tuff).But the other ploblem is the 25amp fuse for the wipers keeps blowing as soon as I turn the key foward
with the wiper multiswitch turned off.Could this be a fried multiswitch or
somthing with the ignition switch or wiper motor.The truck starts and runs fine turn singnals and high and low beams work so I don't know if it could be the multi switch.Any help would be very much apperciated!!!
Thanks
Old Jan 15, 2009 | 10:24 PM
APA228's Avatar
APA228
There is a wiper relay in the power distribution center that could be the problem. Remove it and see what happens.
Old Jan 15, 2009 | 10:26 PM
PurplDodge's Avatar
PurplDodge
Well, I need to smack your son across the face.
Old Jan 15, 2009 | 11:14 PM
SmokeGrinder's Avatar
SmokeGrinder
ive noticed in threads you talk like your something when your really nothing...
Old Jan 16, 2009 | 01:18 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Hes calling you out!
Old Jan 16, 2009 | 01:37 AM
JackJ's Avatar
JackJ
I did this once on my JEEP and ended up frying a starter, a battery, and melting a set of Cables to a friends truck, he wernt to happy about that.
Old Jan 16, 2009 | 10:23 AM
pcfixerpro's Avatar
pcfixerpro
I gather the same conclusion. Just a know it all 13yr old.
Old Jan 16, 2009 | 10:36 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Thanks
First of all, jumper cables have to be connected properly:
Source vehicle:
Red - Positive Post
Black - Negative Post
Jumped Vehicle:
Red - Positive Post
Black - GROUND (ie. an engine bolt, chassis, etc) NEVER DIRECTLY CONNECT THE BATTERIES
People also believe this notion that cables are to be connected Positive to Negative, Negative to Positive. Again, THIS IS INCORRECT.
Old Jan 16, 2009 | 01:25 PM
dillonjm's Avatar
dillonjm
Source vehicle:
Red - Positive Post
Jumped Vehicle:
Red - Positive Post
This is actually a pretty good tip regarding the ground connection on the jumped vehicle. You risk an explosion connecting directly to the battery (although i have never actually seen it happen, its better to play it safe).
Old Jan 16, 2009 | 04:02 PM
PurplDodge's Avatar
PurplDodge
What does a joke have to do with me talkin' like im somthin? Don't you think that I know that?
