help with 1997 dodge 2500 360
Old Jan 14, 2009 | 02:54 PM
flowers2424's Avatar
flowers2424
Default help with 1997 dodge 2500 360
cranks up and drives down the highway just fine but when you slow down it will just shut off i changed out the fuel pump figured that was the problem but is still doing it please help if you have any information
Old Jan 14, 2009 | 08:08 PM
dhvaughan's Avatar
dhvaughan
does it crank right back up ?
does it stay running if you leave a little pressure on the gas pedal to hold the rpm's at around 1000 or so ?
so does it seem like it just can't go from cruising rpm to idle w/o dieing ?
if its an idle problem, replace IAC and if that doesn't fix it replace TPS (and save the old IAC as a spare).
