what the diffrence between the two ???
was wondering what is ther diffrence between a 3ich body lift or a 3inch suspension lift , what is better and what all involved. and prices, i would love to lift my truck , but keep the same tires. i have 2 inch spacers on the front already, was on there when i bought it.
3ich body lift= the frame of the truck stays in the same spot...body move up, also you can now see more frame
3inch suspension lift= frame goes up with the body... the body/frame will look the same but you will have more height
i think suspension lift is the way to go... because later if you want more lift then you can put the body lift
**oh and also with the body lift you have to move your bumps up because they are bolted to the frame**
IMHO go with the suspension lift. All a body lift does is lift the body up a little bit (hence the name). A suspnsion lift lifts everything (minus the differentials, which is lifted with larger tires) off the ground.
