Heater / AC vent troubles
Old Jan 17, 2009 | 11:49 PM
tuck5350's Avatar
tuck5350
Default Heater / AC vent troubles
When I run my heat or ac through my dash vents while driving ,when I accelerate the air switches to my defrost and floor vents as soon as my rpms drop back down the air will switch back to my dash vents,sounds kinda strange,but I have heard of two other people with same problem.Any ideas what causing the problem?
Old Jan 18, 2009 | 06:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Vacuum leak. check all your hoses and the check valves(passenger side of motor). If you have cruise control there is a hose under the battery tray also.BTW, you"ll want to check the whole system not just the heater/ac related hoses. Like the 4 wheel drive hoses, vacuum canister etc....
Old Jan 18, 2009 | 10:13 AM
dhvaughan's Avatar
dhvaughan
welcome to df. do a search on 'wild vents' and 'check valve' for a lot of posts, some include pictures.
Old Jan 18, 2009 | 03:10 PM
tuck5350's Avatar
tuck5350
Thanks for the info on the vent problems,I guess i better get busy looking for some leaks.
