Need Help truck not running right AGAIN
Old Jan 24, 2009 | 08:49 AM
dc9689's Avatar
dc9689
Default Need Help truck not running right AGAIN
So about a month back my truck started giving me problems where id be driving and it would randomly start backfiring and runing very poorly. I took it to a shop they told me it was a bad coil which was replaced and the truck seemed to be fine for a couple weeks and now im having similar problems. Sometimes it wont start so i spray wd40 on the coil and i t fires right up idk what the problem is but if anyone has advice id appreciate it thanks guys.
Old Jan 24, 2009 | 09:45 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Check the primary wire connector at the bottom of the coil. I'm assuming you have a Magnum V8. For some reason my connector stopped "snapping" into place and I've got several tie-wraps on it holding it in place. If it's not that, then I would be looking in the direction of the crank sensor.
Old Jan 24, 2009 | 09:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe the coil is defective, what brand is it? Or maybe the wire is bad or not pushed in all the way.
