Seaform: How To?
Old Jan 26, 2009 | 05:45 PM
98cherryram's Avatar
98cherryram
I thought it looked a little funny on the posting with seaform haha
Old Jan 27, 2009 | 01:27 AM
TIMIDONE's Avatar
TIMIDONE
seafoam or seaform all the same lol my bad
Old Jan 27, 2009 | 11:44 AM
dblj16380's Avatar
dblj16380
Not when it comes to searching the forum though! HEHE
Old Jan 27, 2009 | 05:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I think he did it on purpose! I know I spent an hour searching the web looking for some new product called Seaform.
Old Jan 28, 2009 | 01:50 AM
TIMIDONE's Avatar
TIMIDONE
All my mistakes are done on purpose!
Old Jan 28, 2009 | 11:27 AM
TIMIDONE's Avatar
TIMIDONE
So I am either disappointed OR I just messed up...probably a little of both!
This morning (5:45 AM) I ran my engine to warm up...then I put the Seafoam in my PCV (I think see earlier posted pic, that my PCV, right?) turned it off, put some in my oil and gas....waited umm 10+ minutes and....nada.
Nada meaning no smoke coming out of the exhaust like I thought! It started right up and seemed to drive fine all the way to work...in a little I am getting an oil change.
Does it only smoke if you put it into your brake booster? Or should I had seen smoke when put in my PCV? Just making sure so I didn't F anything up.
Thanks.
Old Jan 28, 2009 | 12:15 PM
Ramman18's Avatar
Ramman18
Here's what to do. Drive to an open area and get the motor good and hot. Leave it idling. Pull off the hose going to the brake booster and the motor will rev up to about 1k rpm and you'll hear a loud sucking sound from the hose. Take the bottle and tip it towards the hose. The hose will suck the liquid so fast it vaporizes it. The engine will want to bog and die. Just let up, let it resume high idle and continue until about half or whole can is used up. Don't let it die while doing this. Then when satisfied with amount, shut truck off. Wait a half hour. Turn it on and let it run awhile giving it small revs. Then take it out and run it hard, going through the gears. The smoke may take awhile but it should come. If there isn't much smoke, after 10 minutes of doing it this way, try it again in a week. The first time I did it this way, not much smoke at all but a little as I drove it hard. Tried it again after a road trip and TONS of smoke.
Old Jan 28, 2009 | 12:28 PM
dblj16380's Avatar
dblj16380
Maybe it just takes two runs in order to free up 8-10 years worth of junk building up in there?
Old Jan 30, 2009 | 05:20 PM
PurplDodge's Avatar
PurplDodge
When I pour the Seafoam into the motor, Is the motor sopossed to be on?
Old Jan 30, 2009 | 05:53 PM
PURPLE.ppl.EATER's Avatar
PURPLE.ppl.EATER
sorry brake booster. where is this?
