Rancho 5000's
Old Jan 28, 2009 | 01:16 AM
RJTDakotaBoy's Avatar
RJTDakotaBoy
Default Rancho 5000's
Hey all. Long time since I've been on here. I have a 01 Ram 1500 Quad Cab 4x4 and I recently replaced the front shocks with Rancho 5000's. My problem is when I drive it now sounds and feels like something is banging on the floorboard of my truck. When i bounce on the front bumper I can feel the banging throughout the truck on all parts of the body and on the steering linkage. When I replaced the shocks I undid the stabilizer links and lowered the front diff then moved the coils so I could pull out the shocks. I replaced everything as it was so I was hoping some of you had an idea of what my problem might be. Thanks for any help
Old Jan 28, 2009 | 01:27 AM
Viper37's Avatar
Viper37
Make sure your sway bar is centered, and not off to one side, clipping your upper coil mount.
Old Jan 28, 2009 | 01:30 AM
RJTDakotaBoy
that would make sense. when i tightened the one side the link turned a bit so it prob pulled the sway bar off to the right
Old Jan 28, 2009 | 06:30 AM
Vader's Avatar
Vader
Also, make sure they is no play in the bushing at the top of the stock.
Old Feb 15, 2009 | 02:21 PM
RJTDakotaBoy
So I just worked on the truck. I pulled the sway bar to be centered, and I checked the bushings and still I have a slight banging. It got better but it is still there. Also I noticed a squeak in my dash, and it pinpointed it to the steering shaft in the engine bay just before it goes through the fire wall. I keep spraying it with WD-40 and Super Lube and it helps momentarily. Any idea on that as well? Help greatly appreciated
