getting on highway and check engine light blinks
Old Jan 31, 2009 | 04:48 PM
nathangfnd's Avatar
nathangfnd
Default getting on highway and check engine light blinks
I was getting on the highway today and when i was getting up to speed it started to sputter or lightly back fire. It started around 55 mph and stoped when i traveled for a few hundred feet. I slowed down and tried it again and it did the same thing.
So i went back to town and noticed it did it now at slower speeds whenever putting my foot on the gas.
All fluids seem to be ok and and no gauges are off. and the check engine only blinks when i am starting to gain speed.
Any Ideas on what it could be.
Old Jan 31, 2009 | 05:10 PM
froesen's Avatar
froesen
Flashing CEL is a multiple/random misfire, if you checked your codes you'd have at least a P0300. If you haven't done so in a while, it's probably time for new cap/rotor/plugs/wires. Make sure you follow the tsb on wire routing, they get crabby if you just bunch them together. And no platinum plugs. There are lots of threads on here discussing plugs, but the champion truck plugs and autolites are from what i remember the "acceptable" ones.
Old Jan 31, 2009 | 07:57 PM
nathangfnd's Avatar
nathangfnd
So is it bad to drive it like this?
Old Jan 31, 2009 | 08:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the fuel pressure, cat and plenum also. http://dodgeram.info/tsb/2000/09-05-00.htm
Old Jan 31, 2009 | 10:23 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Misrouted plug wires on #6 and #8 can cause this problem.
Old Feb 1, 2009 | 02:08 AM
nathangfnd's Avatar
nathangfnd
nothing in the motor has been touched in about a month. which is when i put a new battery and alternator in. And normal fluid fills and just checking to see if anything is bad. But i have not taken anything but the alternator off in 6 months.
If it is plug wires/distrbutor why the HELL does it have to be si difficult to get back there. I was going to see about pulling it apartr tonightbut when i got the K&N air filter system off i just said F@#$ it. which was at like 1:00am
Old Feb 1, 2009 | 09:28 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
It could also be an injector plugged on the inlet side. Let the truck idle and then unplug an injector. If the idle changes, then the injector is OK; otherwise, there's a problem.
Old Feb 1, 2009 | 03:17 PM
nathangfnd's Avatar
nathangfnd
Just got the check engine light scanned and it came up with cylinder 2 misfire.
Any ideas
Does anyone know which one is cylinder #2
Old Feb 1, 2009 | 03:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
While sitting in the driver's seat --
Left bank, from front to back: 1,3,5,7
Right bank, from front to back: 2,4,6,8
Old Feb 1, 2009 | 03:35 PM
zman17's Avatar
zman17
Check the plug, plug wire, cap and rotor, and the injector as VW stated above. And get a Haynes manual.
