Dana 60 swap questions..
Old Feb 4, 2009 | 09:49 PM
Kraiger's Avatar
Kraiger
Unhappy Dana 60 swap questions..
I have a 2001 dodge ram 4x4 sport off road. I am putting a Dana 60 in front and rear. The front dana 60 is out of a 1996 2500. I am putting a CAD delete and manual hub conversion on it. I would like to go with the 00 brake set up but the 1996 knuckles are no built for the 00 two piston calipers. I did not know if i could just use 00 knuckles and they would fit the 96 axle. I know the ball joints and different part numbers. Just asking so i dont go and spend a ton of money and turn out it is not going to work..so if anyone can help id love to hear what you have to say.. Thanks
Old Feb 4, 2009 | 10:02 PM
95MaroonMonster's Avatar
95MaroonMonster
the axle housing as far as i know is the same for all years, so the different knuckles should work
Old Feb 4, 2009 | 11:33 PM
olyelr's Avatar
olyelr
Thats a good question. I would be just guessing to say that they are interchangeable (although I think they are). But, if the ball joints are different for the two knuckles then that might mean they aren't. Maybe you could go measure up one from a newer dodge in your area to get an idea?
Dang, sinking some money into the 60 with the hub conversion eh. What kit did you go with, EMS? 35 spline? Wish I could pull that off... I's envious.
Good luck with the swap. Post pics of progress
Old Feb 4, 2009 | 11:36 PM
95MaroonMonster
the ball joints may be different on just the knuckle side, so its possible that you could use the different knuckles, by using the correct ball joints
Old Feb 4, 2009 | 11:38 PM
Kraiger's Avatar
Kraiger
I was going to go with a dynatrac but then when looking at the ems kit its cheeper but uses the same parts..and yes im going with the 35 spine outters. Wish i could do 35 inners as well but maybe the next build i will. Chromoly shafts should stand up to all i can give it..haha
Old Feb 5, 2009 | 01:22 PM
Kraiger's Avatar
Kraiger
Heres and new questioin...Does anyone have for sale or know where any are for sale...00-02 2500 dana 60 knuckles?
Old Feb 5, 2009 | 01:28 PM
olyelr's Avatar
olyelr
I take it you found out they were interchangeable?
Old Feb 5, 2009 | 03:10 PM
Kraiger's Avatar
Kraiger
Well i talked with the Dodge dealer in town and we looked at two on there lot...The head mechanic there says it should work because they did not change the housing its the a change in knuckles.
Old Feb 5, 2009 | 10:19 PM
olyelr's Avatar
olyelr
Gotcha. So like 95maroonmonster had stated, all you need to do then is buy the correct ball joints for the newer knuckles and it should work. Easy enough, except good luck finding a used set... and I bet they are a pretty penny new !
Old Feb 6, 2009 | 12:01 AM
Kraiger's Avatar
Kraiger
Im finding it very hard to find any.. and im kinda up in the air still if this will work i was reading this.....http://www.pavementsucks.com/forums/...hp?topic=88687... and im kinda confused now..haha....Maybe im just not reading things right( known to happen) but they are saying its not going to work....that the balljoints are mounted different.
