P0601 code in my PT Cruiser
Old Feb 8, 2009 | 10:37 AM
oiler's Avatar
oiler
Default P0601 code in my PT Cruiser
Any one familiar with the P0601 code. It popped up in my wifes car and will not clear. Everything I read says it needs a new ecm. The car runs ok but I am concerned that it may suddenly take a dive. Any ideas on cost of repair or if drivability will be an issue till I can get it repaired. The code reads: internal control module memory check sum error. Thanks in advance.
Old Feb 8, 2009 | 12:51 PM
sawtooth's Avatar
sawtooth
Default Pt p0601
Not much help, but you might checkout this site and search for P0601: http://www.ptdoityourself.net/tl/tl_index1.html#8e.
They claim its not an expensive repair and may be covered by warranty.
Old Feb 8, 2009 | 01:21 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
I am not an expert, but from what I understand, the P0601 code (checksum error) can be a hardware or firmware error. If you just flashed in a custom tune and come back with a checksum, there is a very good chance that it is only programming glitch in the custom tune and a corrected tune will fix the problem. However, if it just started out of the blue, it is most likely a bad PCM (hardware issue).
Old Feb 8, 2009 | 06:26 PM
oiler's Avatar
oiler
15,000 out of warranty. Everything I've read points to a bad computer. Any idea what this is gonna cost?
