broken spark plug
Old Feb 11, 2009 | 10:43 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Whoever cross-threaded it probably did it with an air ratchet and just kept on truckin. That's why I'll do my own "tune-up," thank you very much.
Sorry this happened to you, OP.
Old Feb 11, 2009 | 10:50 PM
charlie1935's Avatar
charlie1935
That's why I start them with my fingers. Ain't cross threaded one in 55 years.
Old Feb 11, 2009 | 11:04 PM
dhvaughan's Avatar
dhvaughan
i couldn't start mine with my fingers with those stupid heat shield on. either my shields were too long or my fingers were too short. a good tip is a piece of vac tubing on the end of the plug. knock on wood i haven't crossed one yet.
Old Feb 11, 2009 | 11:20 PM
Rex-TheDOGG
I use a spark plug socket with a universal joint on the end. With an extension plugged into that, I've never had a problem starting a plug. I like the heat shields because they help me get it started at the right angle. I can feel pretty quickly if it's crossed up.
Old Feb 12, 2009 | 10:11 AM
ophidia's Avatar
ophidia
I also start them with an extension and socket. I've never cross threaded one either, and before this all of my vehicles had aluminum heads.
Old Feb 12, 2009 | 04:18 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by dhvaughan
i think those stupid heat shields increase people's tendency to cross thread them.
that's why i removed mine.
How do you remove them? Its also a PITA because I cant get them out with my fingers when they are untightened.
Old Feb 12, 2009 | 04:26 PM
Rex-TheDOGG
Take a heater hose clamp and tighten it around the shield and pull it out.
Old Feb 12, 2009 | 05:00 PM
pcfixerpro's Avatar
pcfixerpro
get a plug socket with the rubber in it.
Old Feb 12, 2009 | 05:08 PM
PurplDodge's Avatar
PurplDodge
That still won't work for some reason.
