Lubricant specs
Old Feb 12, 2009 | 08:32 PM
BlueRamSport's Avatar
BlueRamSport
Default Lubricant specs
Alright, all the books seem to have a different opinion...
Truck is a 2001 Ram 1500 4x4 5.9 engine.
Haynes says Dex3 for transfer case, factory service manual says ATF+4. Which is it?
For differential lube, Haynes says 90W and factory service manual says 75W-90. Opinions?
Thanks.
Old Feb 12, 2009 | 09:11 PM
dhvaughan's Avatar
dhvaughan
t-case -> atf+4.
diff. -> doesn't matter. its all GL-5 rated. further complexity is the front diff specifies 75w-140 synthetic. i just use 80w90 or 85w90 in both.
Old Feb 13, 2009 | 01:34 AM
rabbler's Avatar
rabbler
Dex III or ATF+ either is fine. ATF+ is better.
Chrysler back spec'ed ATF+4 to replace all earlier ATF+ and many Dex III applications.
Use 75w90 in the diff or 74w140 synthetic if you tow.
Old Feb 13, 2009 | 06:17 AM
HammerZ71's Avatar
HammerZ71
When I had my '98 RCSB 1500 5.9 4x4, I'd use ATF+4 in the transfer case, Lucas 75W-140 conventional in the rear (towed a bass boat regularly), and 75w-140 Mobil 1 in the front.
Reason for the dino oil in the rear was, just like in my current 3rd Gen, I had an Auburn LSD, which specifically says NOT to use synthetic lubes with it.
I do almost the same now, except I've become a believer in Royal Purple, so I run that in the front diff and everywhere else except the rear pumpkin...
Old Feb 13, 2009 | 10:07 AM
Aubrey's Avatar
Aubrey
It probably doesn't matter now but, the factory holds your warranty, not Haynes. That Haynes manual is probably for a wide range of years and their recommendations may be from the earlier years in that range. Plus, the factory manual has probably been updated more recently.
