Tell me it is not my Tranny
Old Mar 24, 2009 | 09:15 PM
  #31
FarmersTan's Avatar
FarmersTan
Originally Posted by dblj16380
Thanks a lot zman. I figured it was around here somewhere but I couldn't find it. When I took my trans out I broke the steel return line at the trans. When I replaced it I didn't have a quick disconnect tool so I took it apart at the check valve location to replace it and then I must have thrown away the new check valve rubber line. Now I am worried that it will clog up so I am going to do away with it. I also put in a Transgo TFOD JR shift kit so that should take care of the TC drainback issues/worries with removing the check ball.
I thought our trannys dont pump in "P"?
Old Mar 24, 2009 | 10:56 PM
  #32
aim4squirrels's Avatar
aim4squirrels
they will with the replacement manual valve available in many shift or overhaul kits.
Old May 4, 2009 | 10:50 PM
  #33
madmax0r's Avatar
madmax0r
crap, mine is doing the bumping forward thing... and has been for a long time.
and I have a somewhat loud tapping noise coming from my torque converter area! =(
Old May 5, 2009 | 08:21 AM
  #34
jgcox6's Avatar
jgcox6
if you do decide to put on a tranny cooler...like a B&S high performance cooler...they tell you to still go through your radiator cooler first then to the add on cooler. It's just more air flow to cool more.
Old Jun 28, 2009 | 05:31 PM
  #35
beamwalker's Avatar
beamwalker
Question
tiggamonster,what did you end up paying on the rebuild ???
Old Jun 29, 2009 | 06:08 AM
  #36
anesthes's Avatar
anesthes
I don't know about him, but I had mine done at Atlantic in Amesbury, MA.
$2600, 3 year 36k. transgo shift kit, checkball mod, and cross drilled mainshaft for more lubrication.
-- Joe
Old Jun 29, 2009 | 06:19 AM
  #37
zman17's Avatar
zman17
Retired Moderator - RIP
I see you are from Salem, Anesthes. I'm a L.I. transplant living in Raymond. And yes I'm a Yankees fan,
