Hollowed out cat
Old Feb 20, 2009 | 03:44 PM
tsparr's Avatar
tsparr
Default Hollowed out cat
Hey guys, I'm kind of an exhaust retard... a while back my dodge started losing GOBS of power so i did all the normal things that i could think of such as replacing spark plugs, new cap and rotor, tps sensor, map sensor... the works. well, finally i thought that maybe... just maybe something was blocking the exhaust, so i unbolted the exhaust at the flanges (where it connects just above the cat) and holy crap it ran fine (but loud). so then i sawed my cat off and the honeycomb was completely melted shut. so being the redneck that i am i just ran a piece of pipe through the cat and completely busted out the honeycomb, then blew air through it to get out all the little pieces left in there out. then i welded the cat back into place so that if my truck gets inspected by the cops, it at least LOOKS like i have a cat. way before all that happened i got a 3" cat back exhaust job done with a super 40 series flowmaster installed. my question is, will not having a cat screw with the power potential of my truck? i replaced both the O2 sensors after all this mayhem, and it threw a code for a while saying that my O2 sensor after the cat wasnt working right or whatever. that code finally stopped coming up, but should i go to the junkyard and pull a good cat off a truck or just leave it? i'm on an extremely tight budget cause i just got out of the army and i dont have a job yet... damn economy, so i cant buy a high flow expensive cat. thanks guys!
Old Feb 20, 2009 | 03:56 PM
pcfixerpro's Avatar
pcfixerpro
Magnaflow highflow ran me around $78 for 3" in/out at a local store. Summit carry's them. You would probably benifit from an o2 simulator for the rear sensor if you do decide to leave your cat gutted and not install a highflow. If they do the sniffer test for inspection I would put a cat back on it. If not, then its up to you.
Old Feb 20, 2009 | 05:00 PM
tsparr's Avatar
tsparr
What I really want to know is because i have a gutted cat is it going to hurt my truck's power?
Old Feb 20, 2009 | 05:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
No cat and 3" exhaust will rob the lower end of some power. But probably not enough to worry about.
Old Feb 20, 2009 | 07:44 PM
TMS Bill's Avatar
TMS Bill
A 3" single is ok but 2.5" duals is about max on a 360. The gutted cat isn't hurting you as long as you don't have have your pipe probed by the state. Save your money until you can afford it. Then, if you feel you really WANT to comply, get a Magnaflow.
Old Feb 21, 2009 | 12:26 PM
tsparr's Avatar
tsparr
Thumbs up
ok if its not gonna rob me of a ton of power i'm not gonna worry about it. in the county i live in they dont require emissions so screw it i'm not payin the money for a new cat. thanks guys.
Old Feb 21, 2009 | 01:09 PM
pcfixerpro's Avatar
pcfixerpro
I would still suggest getting an o2 sim or the non-fouler trick. Might make your truck run a little better.
Old Feb 21, 2009 | 01:26 PM
zman17's Avatar
zman17
I see more probs coming than it's worth.
Old Feb 21, 2009 | 02:40 PM
aim4squirrels's Avatar
aim4squirrels
You can find the "plans" to build your own O2 sim online, just google. That'll help you from throwing codes and get the truck to run smoothly and not waste gas.
You need a real O2 sensor up front and the sim in the back will tell the PCM the cat is REALLY efficient. The O2 sim I run tells my PCM the Cat is 99.2% efficient
Old Feb 21, 2009 | 02:44 PM
deeznutts's Avatar
deeznutts
without the front cat plugged in youre going to run rich..just either get a high flow cat as stated,,or drill and tap a hole and do the spark plug fouler idea...my 02
