What do i need to do to paint aluminum
Hey guys I have aluminum running boards that are getting a bit yellow. I want to sand them and paint em. Anyone ever paint aluminum? Is there anything special i have to do or know. Also I was thinking about painting my rims black. Is that even possible since they have some sort of coating?
Thanks in advance, Erik
whenever you paint aluminum, you need to make sure it is very clean and apply an "etching" primer or else the paint wont stick. I just use the etching primer in a rattle can and block it to smooth the strokes out. then you can do whatever you want with the paint.
As for wheels. if they are aluminum, in order to get proper results, you should sand blast the wheels first to get all the old stuff off, then, once again, use an etching primer. if their steel, just blast n' paint
auto zone has some wheel paint.. i used on my old chevy colorado that i actually traded for my ram.. anyway.. stuff works really good.. i just cleaned the wheels up real nice with soap and water.. let dry, then sprayed away. never had any issue with peeling, chipping, or anything. good stuff.. one can should do all 4 wheels too
+1 a basic rule to remember is whatever the primer looks like, is what the paint will look like. If the primer is lumpy, uneven, has drips, runs, etc., the paint coats will look that way too. If the primer is uniform and even, the paint will look mint.
ill post some pics after I painted the running boards and rims
